I am trying to add a fuel pressure sensor onto the fuel bowl but... plug that I need to take out has the alen wrench port rounded out. Soooo, I was thinking about simply (and I use that word loosely) replacing the Oil/Fuel housing assembly. 2005 F350 6.0
Is there a write up on that? At first glance it looks pretty straight forward but having not looked into it, I'm sure I'm not seeing some hidden gotchas. I can get a housing for anywhere from $145-$180. Of course there is the CAP option where I know sinister diesel has a cap with a port on the top that might work... But I'd have to ensure I can put a 90 degree connector on there and then the Fuel Sensor that has a 22mm nut (for lack of a better word) that would have to clear the top of the cap...
But for this question, how hard is it to remove the housing?
It may be that I can just remove the housing to get a pair of pliers on the plug as opposed to replacing the entire assembly too.
Any advice is welcome!
