brake light stays on all the time even with the switch disconnected
replaced turn/hazard switch assembly same problem
I unplug the harness from the turn/hazard switch lights go out
have voltage on both sides of the brake light switch
Have a complete 1987 F250 4wd, standard cab, 6.9, 5spd, very rusty body
10.25 rear, Dana 50 front 4:10 gears, manual lock outs, manual transfer case
manual windows and locks, rear ABS
no air tilt column and power steering
wiring harness is good only issue with the truck is broken springs in the DMF
The F350 will be converted to 4wd and 5spd , not using the Dana 50 for this.
under the hood on the 350 looks like all the cruise control components are there
would the under dash parts from the 87 F250 work with the 86 F350 for cruise control
and possibly fix the brake light problem
I haven't gotten into taking apart anything from under the dash on either truck yet
