'2011 spring codes 6.7L
1 reading
22K views 13 replies 8 participants last post by  blwnsmoke
#1 ·
Can anyone help me figure out what I have for front springs? I know based on the truck configuration some trucks automatically get a certain spring,I wanna know for possibly putting a plow on.would this be considered a HD front end?
Here is what the tag says:
5AE
5C34
5310-AEC
Thanks in advance:thumbsup:
#3 ·
Thanks i will check this a.m ....So I'm good to go if it says 5900 or more:thup:
I'm sure it will never snow again if I get one :lol:
#4 ·
Looking at the 2011 Order Guide it shows that you could possibly have the heavier springs depending on what the truck has for a couple other features.
If your truck has 17" or 18" tires then the Axle ratios were either 3.31 or 3.55.
However, in the order guide it showed if your truck was to have the 3.55 ratio with the 17 or 18" tires then the truck required one of the following options listed below.
Requires one of the following options; Heavy Service Front Suspension Package (67H), Heavy Service Package for Pickup Box Delete (63R), Snow Plow Prep Package (473) or Camper Package (471)
The Options info from the 2011 SD order guide
SNOW PLOW PREP PACKAGE (473)
Availability:
• Optional on all 4x4 Pickups
Not available with:
• Heavy-Service Front Suspension Package (67H)
Requires:
• 4x4
Includes:
• Computer selected springs for snowplow application.
• Extra Heavy-Duty Alternator (67D) w/Power Stroke® diesel engine
(Heavy-Duty Alternator with gas engine)
Options Available:
• Dual Alternator (67A) (Diesel only)
NOTE: Restrictions apply; see Supplemental Reference or Body-
Builders Layout Book for details
CAMPER PACKAGE (471)
Availability:
• Optional on all Pickups
Not available with:
• 20" Wheels and Tires, Pickup Box Delete (66D), 3.31 Axle Ratio
(on 4x4 with 17" or 18" tires) or Heavy-Service Front Suspension
Package (67H)
Includes:
• Extra heavy-service front springs (4x2) (2 up upgrade above the
spring computer selected as a consequence of options chosen. Not
incl. if maximum springs have been computer selected as standard
equipment)
• Heavy-service front springs (4x4) (1 up upgrade above the spring
computer selected as a consequence of options chosen. Not incl. if
equipment)
• Rear stabilizer bar (SRW only)
• Slide-in camper certification
• Rear auxiliary springs (F-250 only)
NOTE: Salesperson's Source Book or Ford RV Trailer Towing
Guide should be consulted for specific Trailer Towing or
camper limits and corresponding req. equipment, axle
ratios and model availability
HEAVY-SERVICE FRONT SUSPENSION PACKAGE (67H)
Availability:
• Optional on all pickups
Usage:
• Recommended only on vehicles which will permanently utilize
aftermarket equipment such as Heavy-Duty winches, brush guards
or other apparatus which loads the front axle to the specified Gross
Axle Weight Rating (GAWR)
Not available with:
• Snow Plow Package (473), Camper Package (471) or Heavy-
Includes:
• Heavy-service front springs (1 up upgrade above the spring
equipment)
NOTE 1: May result in deterioration of ride quality.
NOTE 2: Vehicle ride height will increase w/the addition of this
package.
#5 ·
I checked before i left work and nope looks like i'm smoking sausage! 5000 lb front axle 17 " wheels 331axle bummer I guess the good news is i wont be beating the snot out of my front end. thanks
#6 · (Edited)
I had a set of 5,200# in my front end. I swapped them out for the 6000# springs, for the same reason- so I could plow. The only things that are added/changed to plow prep vehicles are heavier springs, and either the "extra heavy duty Altenator, or dual altenators. The axles and everything else is identicle. Easy swap. Order them from Tascaparts.com cost +10% $83.04 a piece. This TSB lists the spring codes and part numbers. If you order them from Tasca just don't enter your VIN on the order page, or they will assume you ordered the wrong part.
The ones you want are the set that end in ACC, those are the 6000# springs
PART NUMBER PART NAME
5C3Z-5310-CA Front Spring (ACC)
5C3Z-5310-DA Front Spring (ADC)
5C3Z-5310-EA Front Spring (AEC)
5C3Z-5310-FA Front Spring (AFC)
F-Super Duty Monobeam Coil Spring Rates (F250/350 4x4)
Front GAWR Rating Current Vehicle Spring Coil P/N 5C34-5310- Intall F250/F350 2-UP
4000 AHC AFC
4400 AGC AEC
4800 AFC ADC
5200 AEC ACC
5600 ADC ACC
6000 ACC No Replacement Part Available
11-4-19***4X4 ONLY - BANGING/CLUNKING NOISE WHEN DRIVING - CONTACT WITH JOUNCE BUMPER - COLD TEMPERATURES
#7 ·
Also- read the TSB and what it's about, probably wouldn't be hard to convince them that you "need" the springs because your "getting a banging, clunking noise in cold weather" it's the right time of year for it- the fix would be to install the 2-up springs in your truck. If you have the AEC- springs already, then the ACC springs would be the ones they'd install for you according to the TSB. good luck.
#9 ·
my truck has goofy spec's I have the optional HD alternator so I guess all I need to do is change the springs and I would in affect have the plow pkg? why the truck has that and not a plow pack is weird Isn't this a cheap option? they wacked me 75.00 for the alternator :eek:rder:
#11 ·
Has anyone else confirmed that the springs for the snow plow package are 5C3Z*5310*CA? My parts department references them as part of package 473 (Snow Plow Package) on a 13. I want to upgrade on my '12. Just a little gun shy since they messed up my other order! Thanks.
#12 ·
Spring codes
If you don't trust your parts guy. Call Tasca they know their stuff-
But the chart is the chart.
Follow the table below to select the correct spring to install based on the vehicles front GAWR rating. Follow the instructions in Workshop Manual, Section 204-01A.
4000 AHC AFC
4400 AGC AEC
4800 AFC ADC
5200 AEC ACC
5600 ADC ACC
The ACC springs are the plow springs. Another option- go to a dealer and find a truck with the plow prep and read the tag on the springs in that one. The tag is easy to see and read.
#14 ·
Good to know.. When I had my 07 F250, it had the 5,200 spring an no plow prep package. Back then, the plow prep package with Ford was Roof markers, different fan clutch and stiffer springs.
I changed out the fan clutch and had the 6,000s put on. I honestly couldn't tell a difference in ride quality without the plow on so I believe exactly what you said about not noticing a difference between the 6 and 7k springs.
