I really have enjoyed reading some of the threads and the vast knowledge you guys seem to have. Here is my problem and I would sure appreciate some help before I go to the shop again.
HISTORY:
1998 4700 International 26,000lb straight truck with the DT466E. Low Profile
250 hp Allison World 6-speed transmission. 3 computer system.
I drive the truck long distance about 5 times a year for 2000miles. After 10 years I have only 210,000 miles on the truck. The truck had all the power I could have ask for. The 250ho was a joy to drive.
In Nov 2006 at 198,000 miles I had a water pump failure and over heated the engine a bit. International shop replaced the water pump and all seemed well. The next week I went on one of my long trips and got 600 miles when the engine just started to slow down. Pulled off the road for 5 minutes, started back up and all was fine for 10 minutes then slowed again. Engine was not over heating, just slowing down to 15MPH.
I was within 3 miles of a shop in NJ I knew of. They did an in-frame overhaul. From that point on I have not had the great power I was accustomed to. Engine starts fine, runs fine, but lacks any great power from a start or any kind of load like the smallest incline.
I have had it in the International shop numerous times looking for the problem but to no avail. Finally, 2 years later, I have learned from a different shop that services the Allison trans that I have only 3lbs of boost. Also it seems I have a good 2600rpm but a stall test of between 1000 - 1200rpm.
Checked the cooler & hoses and found no leaks.
The in-frame did not replace the injectors but did replace the head plate behind the water pump. Also in-frame replaced one exhaust valve and a rocker.
OTHER THOUGHTS: I'm not a mechanic so I really am guessing below:
This 3 lbs boost seems to be the key.
Could it be other exhaust valves not sealing.
Does this model turbo have a wastegate. I'm told no. If not then what controls the turbo speed and pressure? Maybe that is the problem.
I notice that sometimes when I have a lot of power, but not all the power, my transmission temp gauge is elevated. I have noticed the temp gauge is sometimes sporadic and often in the winter sits at 100 degrees.
Maybe Computers not talking. Local International shop seems to have a problem checking all 3 computers. What about installing a wiring harness for a single computer from a 3 computer system?
Lastly injectors? But what would they have to do with low boost.
Help please!
HISTORY:
Help please!
